Don't take this wrong, but are you welding with an AC machine, or a DC machine, and if a DC machine, what polarity are you welding on? Saying that you had some E7018AC and that it worked fine makes me think that your machine is an AC machine. Regular E7018 will stick very badly when it is run on an AC machine, thus when you increase the amperage to the point where you are saying that it will run, but the rod turns orange and seems overly hot it is because of that very reason. If you are using a DC machine, the polarity should be set to reverse polarity, meaning electrode holder + and ground clamp -. Forgive me for the simplistic answer but the information that is in your post doesn't give a lot to go on. aevald
