Up Topic Welding Industry / General Welding Discussion / Available welder jobs in Alaska
- By BamaDave (**) Date 12-02-2005 19:31
All,
I received this information and thought I would pass it along for anyone interested.
David
Veco Alaska has immediate openings for Pipe and Structural Welders to work in our module fabrication shop in Anchorage, Alaska. Three (3) month assignment.
$24.50 per hour for Pipe Welders
And
$21.00 per hour for Structural Welders
Working 6 X 10’s with $60.00 /Day Per Diem.
First and last ticket supplied.
Resumes should be e-mailed to careers@veco.com,
Or fax to (907) 550-8806, or call Bryan Kloster at
(907) 550-8174
Pipe Welders need to be proficient in the following processes:
Tig/Stick on 2” pipe
Tig Root, Stick Out
Stick/Dual Shield (fluxcore) on 6” Heavy Wall
Stick Root with fluxcore (wire feed) to cap it off
Structural Welders need to be proficient in the following process:
Stick and Fluxcore: Both tests are on a 1” plate in 3G (vertical) and 4G (overhead) positions.
