Is there any good online guide that tells you what is the best/acceptable rod (material type) to use for the metal you are trying to braze. Also if it could tell you which flux to use for the rod/application would be great. There is so many types of flux and rods to choose from I simply just don't know exactly where to start. Thanks for the help you provide here:).
