I am a drafter not a welder just to let you know up front. I have a sheet metal part that I want to fill in the corners where bend relief has left holes. The trick is that when all is said and done I don't want it to look as though there were ever holes there. How have you seen this anotated on a drawing? Would this be a plug weld or a fillet weld or something else?
