Hey Justin,
I'm not sure what test number this one is, but I'll call it 3G Inverted. Don't even get nervous, just make sure the root goes on with complete fusion of both sides of the beveled cupon. You can do it by turning the heat up about 10 degrees hotter than would be your typical vertical position (Considering any overhead requires more heat just because of gravity alone). Do little tight circles quickly back into the puddle, or slightly weave between the two, ensuring complete penetraion of both sides. This is typical of an open root, but you have a backing strip, so go bionic. You also have a grinder, the most important part of any weld.
When doing the weld, just stay loose and don't grip onto the stinger, just let it flow. If you can get a cut wheel on the grinder, that helps too. Just be sure and dig into the toe's of the weld to get all of the slag, but dont make thin little cuts, those will become filled with slag on the next pass if you do. Just be neat and relaxed, you'll pass everytime!
