That's a new one on me-- after 20+ years of welding inspection-- several of those years as a third party vender inspection for Alaska State DOT and Public Facilities (almost everything that goes up north is galvanized) I've never seen this phenomena. I have had to follow material to the galvanizer and witness the procedure and the post cleanup.
So, this attracts more tin/zinc to the area that has more silicon then? They should be able to grind the galvanized welds smooth without hurting the galvanize then, eh?
Thanks guys, we learn something new all the time.
Roger
