Up Topic Welding Industry / General Welding Discussion / Clear tig cups?
- - By Metarinka (****) Date 12-19-2005 10:22
Hello I'm wondering if anyone has any information on where to purchase clear tig nozzles
I've heard they are made out of fused quartz, pyrex, or specialized translucent ceramics.
I'm looking for the "standard" threaded cups. I found one brand but they were push on and took a custom collet holder, collet and gas lens etc.
I've seen them referenced before in material and I found some for micro torches. But none for more standard torches. they surely must exist
any help would be appreciated.
Parent - By SWP (**) Date 12-19-2005 15:10
I've only seen the push on type.
http://www.ckworldwide.com/
Parent - By medicinehawk (**) Date 12-20-2005 00:21
I have only seen them on micro torches and they were the "push-on" type. They are not very durable I can tell you that.
Parent - By T0M (*) Date 12-21-2005 12:35
I havent seen any threaded pyrex cups, only push on type.
here is another source that is a little cheaper than ck
http://www.tigdepot.com/products/p34TPLDKits.html
Parent - By ridesideways (*) Date 12-26-2005 22:17
brittle materials like quartz, pyrex don't hold up well when repeatedly threaded on and off. probably manufacturers avoid making them for that reason.
Parent - - By Dr. D (*) Date 12-28-2005 07:53
HTP sells them
Parent - By SA-200 (**) Date 01-06-2006 04:56
Do they work good for ya? Im wondering is the glass would get smokey easily..
