Assuming you intend to work within the guidelines of any welding code, they would have to qualify in SMAW if you intend to have them use that process. Otherwise, there is no need.
Charles
Might be sounding like a smarta** here, but doesn't D1.1 limit minimums to 1/8"? Dunno, I guess if the right set of PQR coupons was run it could be unlimited (speaking on the lesser thickness) to .646" GTAW will definately not qualify the welder to run SMAW but if the work warrants then I'd run the SMAW process too, from the original post it seems nearly impossible to answer if SMAW would be needed... dunno what the range of materials is on the job, etc., etc., etc.,
Welder qualification limitations are specified by the welding standard or code being used. However, that being said, the welding process is considered to be an "essential variable" by all of the welding standards I've had experience with. If the welder is currently qualified for GTAW, a switch to any other process, i.e., SMAW, FCAW, GMAW, etc. would require requalification. Again, as mentioned in one of the other replies, you only have to qualify the welder for those processes to be used in production.
