You may need the help of a local, knowledgable CWI to help guide you through D1.1, in particular, the Qualification section. What you seem to be asking for would take some considerable time to cover in a single post. But if you have the time you can post some of the more direct questions and we'll be glad to help where we can.
Couple questions to get you started with the welder qualifications:
1) welding process(s)?
2) welding positions required? (ie. no sense qualifiying welders for positions like overhead or vertical if all weldments can be positioned in flat or horizontal positions)
3) types of joints? ie. all fillet welds, or are there groove welds also?
4) thickness of materials to be joined?
5) types of materials to be joined? ie. ASTM #'s
This should get you started, there will be many more to come as you answer these.
John Wright
