With all due respect to 5354,
Welding GTAW aluminum does not require a balled electrode.
There is no reason to hold to the outdated notion of balled electrodes unless an old power supply or a poor performing electrode is selected. The lower melting point of Pure (green) electrodes have tradionally forced the balled end. Zirconium (Brown) electrodes may be balled or pointed depending on performance requirements. Thorium, Cerium and Lanthanum doped electrodes won't properly ball.
This topic has been covered in depth in this forum and a search of the words "tungsten electrode" will provide ample backing. Furthermore, any edition of any reputable welding textbook in the last 15 years has good coverage of GTA electrode tip prep for aluminum, not to mention Miller, Lincoln, Hobart, Boieng, General Electric standard practice and training manuals.
Here are a list of conditions that require a balled tungsten:
1, Pure tungsten electrode. (The low melt point makes pointed tip prep impractical.
2, AC power supplies that do not provide square wave output. An old style sine wave will produce too much dwell time on the DC+side of the half cycle to allow for pointed electrodes.
3, An air cooled torch that will not keep an electrode cool enough to keep the point on a given electrode.
4, A desire by the welder to produce a wide shallow penetrating bead profile.
Any power supply that provides AC and Balence control may make use of pointed electrodes when the balence control settings are over about 70% EN.
Try it for yourself and see :)
Lawrence,
"1, Pure tungsten electrode. (The low melt point makes pointed tip prep impractical."
This may be hard to believe, but all tungsten-based GTAW electrodes melt at the same temp. The electron-emitting oxides have higher melting points, but they are not actually *alloyed* with the W. They allow the electrode to operate at lower temps.
"2, AC power supplies that do not provide square wave output. An old style sine wave will produce too much dwell time on the DC+side of the half cycle to allow for pointed electrodes."
Not "dwell time on the DC+ side", but sine waves allow too much time at low voltage compared with square waves.
