Up Topic Welding Industry / General Welding Discussion / Miller spectrum 300 Plasma cutter prob.
- By Plate Date 12-27-2005 06:02
Im not sure whats causing this problem, i have been using this Plasma Cutter for about a year with no problems. recently it stopped working, it makes the initial spark when triggered then nothing. If I disconnect the ground lead it cuts fine, I put the ground back on and I just get the initial spark again. Does anyone have an idea what could be causing this problem
