Up Topic Welding Industry / General Welding Discussion / Preheating for Cross country pipeline
- - By GirishSKulkarni Date 12-28-2005 10:39
Can someone advise/suggest about requirement for preheating of cross country pipeline works having Material API 5L X 70, thk 21 mm. Fabrication code is API 1104 and specification is silent saying "as per approved WPS".
Parent - - By CWIScott Date 12-28-2005 17:02
What does your WPS specify? Do you have one? Maybe I can help. If you do not have one you will have to create one per code requirment. I need more info from you. Maybe I can help.
Parent - By GirishSKulkarni Date 12-29-2005 03:41
Dear Mr Scott,
WPS yet to be prepared and approved. However the pipeline is located in Indian subcontinent where early morning temperature in winter is above 10 degree celsius (50 degree F).
Parent - - By G.S.Crisi (****) Date 12-28-2005 17:20
I don't know where is your pipeline located. If it is in a sub-zero (Celsius) climate, I don't need to look at the WPS to say one thing: before starting the weld, the joint must be warm to the hand.
Happy New Year to all the frequentors of this Forum.
Parent - By swnorris (****) Date 12-28-2005 18:15
Job conditions, prevailing codes, high restraint, alloy level, WPS, or other considerations would normally dictate preheat and interpass temperatures, but since you're saying that the code and specification makes no mention of either, in general, the minimum preheat and interpass temperature for API 5L X70 in your posted thickness range is around 200 degrees Fahrenheit.
Parent - - By GirishSKulkarni Date 12-29-2005 03:38
Dear Mr Crisi,
Pipeline is located in Indian subcontinent where early morning temperature in winter, is above 10 degree celsius (50 degree F).
Parent - - By G.S.Crisi (****) Date 12-29-2005 17:25
I would insist in "warm to the hand", but since Mr. Norris has suggested 200 F (about 95 C), I'll agree with him.
Hundreds of times I've read in the specifications (all specifications, not only Welding) the following phrase: "When two specifications apply to the same item, the stricter one shall be followed"; and 200 F is stricter than warm to the hand.
Parent - - By swnorris (****) Date 12-29-2005 18:02
If the carbon content is less than 0.2 and the thickness is less than 12mm (.472), the minimum preheat and interpass temperature is 50 degrees Fahrenheit. If the carbon content is less than 0.2 and the thickness is more than 12mm, the minimum preheat and interpass temperature is 100 degrees Fahrenheit.
If the carbon content is more than 0.2, and the thickness is less than 12mm the minimum preheat and interpass temperature is 100 degrees Fahrenheit. If the carbon content is more than 0.2 and the thickness is more than 12mm, the minimum preheat and interpass temperature is 200 degrees Fahrenheit.
Professor Crisi,
Since we know the thickness is 21mm (.826) the minimum preheat and interpass temperature will either be 100 or 200 degrees Fahrenheit. Not knowing the carbon content, I suggested the stricter one.
Parent - - By G.S.Crisi (****) Date 01-04-2006 18:29
Mr. Norris,
The nominal carbon content of 5LX 70 is 0.26%, so 200 F would be OK.
Now, there are two answers below recommending a higher temperature. It's up to Mr. Kulkarni to decide what to do.
Parent - By GirishSKulkarni Date 01-05-2006 03:24
Dear ALL
Thanks you all .... Feedback of you all has helped me to conclude preheating temperature to 100 degree C. Thanks a lot again ....
Parent - - By chall (***) Date 01-03-2006 14:09
What does your client specify?
When we have welded X70, normally the client specifies a somewhat elevated preheat. In one instance, the client required preheat of 300F for X65 and above.
Charles
Parent - - By Anthony James (*) Date 01-03-2006 22:13
Hi All,
Am currently welding on pipe line parts for LNG pump staion in Holland,FCAW metal filled core and our preheat is minimum 150oC max 200oC, interpass max 250oC,thk 15mm-35mm and i think the grade is the same,will check and let you know.High preheat is to counteract lack of fusion problems
Cheers
AJ
Parent - By pipehead (***) Date 01-19-2006 17:24
I just finished work on a project in Colorado with similiar material the WPS called for a preheat of 200 to 250 degrees farenheit. But the problem with amount of heat was that most of the welders were getting excesive burn through on the root pass so the manufacturer dropped the preheat to 150- 175 degrees also with that much heat the you can have a hard time getting to fill and cap passes to stack.
The morning temps were around 10 to 15 degrees in the morning and warming to around 50 to 70 in the afternoon.
