Presto-Lite tanks are left-overs from the days of acetylene headlamps on automobiles.(Hence "presto" ,you didn't need to wait for the acetylene generator to make enough gas to light your headlamps, you just open the tank and you light your lamps).
Commonly known as plumbers tanks, or 'B' tanks.
They have a right handed thread, which is what KJArtWelder has found on his set-up, " my tank has a male valve and right handed threads".
These tanks have been in existance before there was a 'standard'.
I would guess that tens, if not hundreds of thousands of these tanks are in existance.
