This may prove to be lengthy so bear with me. First I believe you have an AC only machine. You probably have a work and electrode tap connection. You have one set of taps with settings of Highest, High, Medium and Low, this would be the work connection. Or, does your machine have a numbered system of taps? And one set with varying steps or taps of fine current adjustment, this would be the electrode connection. Use an AC voltmeter and measure the open circuit voltage (machine on but not welding) at one of the fine current taps and at each of the Highest, High, Medium and Low taps. This will verify Highest, High, Medium and Low. The open circuit voltage should increase the most with the Low tap. Connect the work lead in the Low tap setting. Then start at the highest fine current setting tap with the electrode connection. Determine this by striking an arc. If an arc is difficult or near impossible to start. Go to the opposite end of tap settings and try that. If there is a real strong arc, it is the highest amperage setting. Now, work down to each tap connection and establish an arc. Very quickly a good welding condition can be achieved.
If you want precise amperage values, for a few dollars a welding machine repair center can load test the machine for each tap setting and record the amperage value. Caution, if they test on a strong 230-240 volt line and you only have 200-208 volts in your garage/shop those values will change.
Hello. Regarding the Trindl welder. I have one of these old machines Model 260A.
The tap designations are on a board that lays over the taps, but under the insulators. There is an insulator on each tap, that threads over the tap. The layout is like this: Left side, as you look at the front of the machine is called (by Trindl) the Major Control. For Electrode. Tap on top is number 1. Going clockwise, to number 6. Right side is called the Vernier (Ground). Top tap is designated A, go clockwise to F. Output amps is as follows: IE: Electrode Cable in hole 6, and Ground Cable in Hole F = 260 Amps AC output.
A B C D E F
1 20 22 24 26 28 30
2 32 34 36 38 40 45
3 50 55 60 65 70 75
4 80 85 90 95 100 110
5 120 130 140 150 160 170
6 180 190 200 220 240 260
Other info. Input is 40amps 220V. Transformer is known to be a quality wired, and heavy duty unit. I had this one checked out by a qualified professional, to make sure that all of the windings were ok. I have never used it, but intend to someday. All I lack are the work cables, and some way to replace the insulators that surround the taps.
I would definitely check out all of the wiring insulation, insulators, etc., before juicing the old gal up !! Hope this helped.
Regards,
John
