Rule #1: If you don't already "know" the information before the seminar, the seminar will NOT pass the test for you.
Rule #2: Study your a** off right up until the day before the test, then relax the night before the test. If you really know the stuff your mind will be needing a slight break in the action.
Rule #3 & #4: Go down through the answer sheet answering the questions you are 95 - 100% certain of, then go back and answer the ones that take more time / thought; MOST IMPORTANT: if you use this rule, do NOT miss a box thereby inadvertently placing the correct answer in the wrong line/box. As much as I hate saying this, when all else fails and you're running out of time... guess. Some chance is better than no chance! Don't leave any question unanswered!
(NOTE: Unaswered questions throws the computer program AWS uses for grading the tests off and then they have to be graded by hand, thus causing more delay in receiving you results!!!)
Rule #5: Another VERY important rule... do NOT second guess yourself once you've made what you believe to be the best answer!
Rule #6: Remember we're all here to give you the best possible advice so study hard, know your material and use the seminar as a refresher, you'll do fine!
Good luck!
