Yes, but I didn't want to get too technical due to the way the question was asked. It is measured in ft/lbs @ a given temperature (usually at 0F or -20F).
John Wright
edit: This is very important information when dealing with Seismic Welded Connections. FEMA 350 spells out the minimums that the materials need to meet. The job specs should indicate what values the engineer wants, this is usually decided by whether or not the structure will be heated or conditioned while in service.
