Asarkar_ kolkata,
The 8 mm plate is reasonably thin and will bend/warp quite easily. If you do not have enough tacks between the 8mm plate and the backing strip keeping it in close contact you will get slag filling the void and this may show as discontinuous indications,
Regards,
Shane Feder
