Up Topic Welding Industry / Technical Discussions / D1.5 RT indications
- - By sbruno (*) Date 01-18-2006 21:34
What is the maximum size of porosity or fusion type indication that is allowed in a 1-1/4" steel plate groove weld?
Following the chart in fig.6.8 it shows 3/8"....True or false?
Thank you all for your continued high level of professional courtesy.
Parent - - By khodabandeh (**) Date 01-19-2006 06:02
Dera Sir,
According to AWS D1.1(6.12.1.1):
Round indications such as porosity not lees than 1/4 in(6mm) when the material thickness is greater than 2 in, the maximum acceptable size porosity is 10 mm.
Best Regards.
O.Khodabandeh
Parent - By sbruno (*) Date 01-19-2006 15:54
O.Khodabandeh,
The code is D1.5 but it would seem that they are both the same, 3/8".
Thank you for your input.
Sam
Parent - - By CHGuilford (****) Date 01-19-2006 14:25
You identified D1.5 as the applicable code. Figure 6.8 addresses discontinuities in tension welds.
The way I interpret the nomograph is that slightly more than 3/8" would be allowed for the maximum size (part way between 3/8 and 7/16").
Chet
Parent - By sbruno (*) Date 01-19-2006 16:15
Chet,
Thank you for concurring with my interpretation.
Sam
