Thanks for your replies. My question is following to my previous one with “ESAB Co. FCAW wires” topic. We are welding shells of some vessels with 48mm thickness in vertical position. After vertical welding shells will be doubled to be welded in their circumferential joint in flat position. There is no way to make vertical joints to flat. We found some side wall lack of fusion in our vertical welds. We decided to do following for next welds:
1. Grinding bevels surfaces to clean and shiny base metal thoroughly, to be sure all scales of flame cutting are removed.
2. Using high inductance and welding parameter to increase heat input as much as possible.
3. Decreasing contact tube to work piece distance as much as possible.
However, our first party of base metal is finished and we are waiting for next party to do three above mentioned items to see the result.
In ESAB technical data sheet is mentioned that their wire nos. “OK Tubrod 15.15” and “FILARC PZ 6113” are high productive wires in vertical position and spray transfer mode. Have you used them before? Is it possible to use them with string bead without weaving? I’ve seen in an ESAB Co. film that one rutile flux cored wire was welding in spray mode in vertical position without weaving; but unfortunately its name didn’t mention during the film.
