India based business person (in New Jersey, US till Feb) interested in representing ONLY MANUFACTURERS of following equipments for use by Boiler Manufacturer and Fabricators in India
1 500 Amps. (60% Duty Cycle) MIG/MAG (CO2 Gas) Welding Power Source with Special Welding Torches(67)
2 600 Amps (100% Duty Cycle) Manual Arc Welding Machine(16)
3 500 Amps (60% Duty Cycle) General Purpose Welding Machine - Inverter Controlled (27)
4 350 Amps Multi-Purpose Welding Machine - Inverter Controlled (41)
5 300 Amps (60% Duty Cycle) Manual Pulsed TIG Welding Power Source (with upslope & downslope) - Inverter Controlled (32)
6 Header Pipe/Fittings Butt Welding Station (Welding Power Source & Head, Job Manipulator, Flux Recovery and Recycling Units) (2)
7 Panel Processing Machine - 20 Torch - MIG/MAG Welding with Fin Calibration - Fume/Flux/Slag Recovery Units (1)
8 Straight Tube Butt Welding Machine with TIG + MIG Welding and Tube Handling Facility (2)
9 High Productive Orbital Tube Welding Station for RH & SH Coil Formation (4)
10 Flash Butt Welding Machine with Process Monitoring Facility - for Coil Formation (1)
contact
bkanjoo@gmail.com
Address in US: 3607, Gates Court, Morris Plains, NJ 07950 Ph. 973 998 4215
