Zeke,
We're cool. No problems here. I was going to e-mail you, but you did not post your e-mail address. I have mine psoted and thought I might hear from you.
Naturally, the sales pitch of most SS FCAW reps is to point out the best attributes of their products. Self peeling slag, or the ease of removal are a big concern, naturally. You know, Bismuth is the chemical alloy added to the flux of the FCAW wires that allow easy removal of the slag. Too little and it will be hard to remove, or may come off in pieces. Too much Bismuth and the weld will tend to have a greater chance of hot cracking due to picking up Bismuth form the coating into the weld. So, there is a fine line there. Some fabricators request a FCAW with no Bismuth to avoid the possibility of cracks. Then, they have the problem of slag removal being less than easy. Others do not concern themselves with the Bismuth. Heck, some fabricators, supervisors, or QC people may not even know what Bismuth is or what it is added to the flux for. I don't know. The oxidizing agents in the flux play a big part in the appearance of the oxide layer after the flux it removed. Granted, different welding process produce different degrees of oxide layers. It is not uncommon to see one brand of SS FCAW with a heavier oxide layer appearance than another manufacturer. Strictly my personal opinion is that I look for a FCAW that has self-peeling or is very easy slag to remove. The less the oxide layer, he better protection you have, in my opinion. But, the bottom line is that regardless of the circumstance, the heat has burned off the chromium protective layer. Like you said, possibly a sales rep would rather have yoou focus on the ease of slag removal than focus on the ugly weld. You know how that goes...An easy slag removal FCAW with "minimal" oxidation shows me that the formulation of the slag if right where it should be. Have a good day, my friend..
Hey Chuck, isn't Bismuth in North Dakota? lol ;-)
Either that or that famous German battleship....
LMFAO!!!! Oh? Well, tell ya what, it's Friday lets all get gassed!
hey guys thanks for all of your help. like i said im still learning. but the more things i read from these post the more knowledge i gain. so, once again thank you
Chuck,
I heard of an instance where a large valve was fabricated with 308L flux cored filler. For some unknown reason, a stress relief treatment was made after welding. The thing nearly fell apart with cracks. Bismuth was blamed. I believe Bismuths melting point is only about 500F. 308H was used on the next one which was also was put under the same PWHT. It was fine. Many people in the US think that in a 308H filler, H stands only for high Carbon. I understand the reasoning for this as all 308H fillers have increased Carbon for high temperature tensile strengths. But obviously from the slag removability, 308H material is made without Bismuth and probably a few other elements that are non-desirable in a high temp application. I wonder how many Stainless jobs have failed due to using the wrong filler materials. I can guarantee that the general welding public has no clue on this issue. I am surprised that the specs don't bring this issue out more clearly. Maybe because Bismuth is used in such a small amount, it is not required to be reported. I do think it deserves at least a footnote somewhere in 5.22.
Zeke
By -
Date 01-28-2006 17:50
Zeke,
Your points are very well taken. I can only assume, which sometime I should never do, that the filler metal specifications relating to SS do not list the "trace elements", or what we consider to be trace elements. Unless I'm mistaken, Bismuth is considered a trace element and is measured in PPM instead of percentages. Such could be said for the rare earth elements. I have also heard some engineers, QC, and others sometimes try to consider the stabilizing elements (Cb, Nb,Ta) as trace elements. I, personally, disagree with that statement strictly because columbium (Cb), niobium (Nb), and tantilum (Ta) are dependent upon the percentage of carbon in the formula in virtually all cases. I guess that the specification does not have a min/max when it comes to requirements of Bismuth in the SS FCAW. Most FCAW manufacturers have already done their homework regarding Bismuth and fully realize the pros and cons of it even in very small amounts. The specifications are requirements of chemistry of the filler metal and don't specify requirements for flux chemistry, such as oxidizing agents and our old favorite, Bismuth. Yes, it would be interesting to see every single element that is involved in producing every grade of wire, trace element or not.
