Up Topic Welders and Inspectors / Welding Equipment Classifieds / TIG Footpedal
- - By Icharus Date 01-28-2006 22:59
I've got a Century 295 amp AC/ 250 amp DC (5 STAR) welder with an HF buzz box kit and TIG conversion. The problem is (of course) that when the argon is turned on, the gas runs continuously through the TIG torch whether the TIG is operating or not and the applied current is a constant and not adjustible. I would like to run a foot pedal with this rig so that the argon flows and the current is applied when the foot pedal is depressed. Can a Lincoln Welder (Lincoln bought out Century) TIG foot pedal be configured to work with a configuration like this?
Icharus
Parent - - By Century ASC Date 01-29-2006 02:09
Icharus,
All of the Century high freq boxes I've worked on in the last thirty years
have had a fingertip control gas valve in the handle (factory model).
Never seen one with a amp pedal; most people set the jack plugs or shunt as close as they can and go for it, as has been covered on this forum a few days ago. You might try Lincoln Electric/WCTA tech service at 86.236.0044, option 3. Good luck!
Parent - - By Icharus Date 01-29-2006 15:03
Thank you Century. I will try just as you suggest.
Icharus
P.S. I am not finding the number 86.236.0044, Can you provide a 3 digit area code or a city/state. Could this be in Cleveland, OH (Home of Lincoln Electric Corporate Offices)?
Parent - - By Century ASC Date 01-29-2006 21:51
Apologies for the typo. These fingers work better wrapped around tools and test equipment than they do on a laptop keyboard.
Toll free: 866.236.0044, option 3.
With the globalization of Corporate America, you can stick workers anywhere ya want - this particular tech line is answered in Minneapolis;
but HQ is indeed in Cleveland.
Parent - - By Icharus Date 01-29-2006 21:57
Thank you - better to be accurate with machinery than with laptops.
I'm just outside MSP so that this is a convenient source.
Icharus
Parent - By 70 c-10 Date 04-17-2007 21:19
Icharus I'm wondering if you have ever found anything out on your situation. I have basically the exact same setup as you and was thinking the same thing about foot control and haven't found anything please reply if you have.
thanks
