First of all, "Thank You" to all who replied to this message. We do not do very much welding here so each time there is a requirement, we need to investigate for proper callout(s).
I will agree that a simple note callout would suffice, but I do have one more question:
If "Tack Weld" is specified, what would the size be? Would this be per an "AWS" standard or just a "workmanship" standard?
I'm thinking that if there is concern about the weld, we would have to specify a fillet with a desired size.
Thanks again everyone.
