Up Topic Welding Industry / Inspection & Qualification / tube/pipes welding data
- - By lalit4bearings Date 02-02-2006 15:56
please someone must explain me in detail what are the basic requirements to weld low carbon erw pipes and the gap to maintain between two faces,what alphabets mean,std. values for distructive tests etc. Help me out.
Parent - By jon20013 (*****) Date 02-02-2006 17:00
Sorry to say but I believe you need far more help than can be offered here at least with as broad as your question covers. To many attributes.
Parent - By jfwi (*) Date 02-02-2006 19:34
Don't know what process your going to use but the standard gap is 3/32" to 1/8" with no land up to an 1/8" land. The test coupons with be taken from 2 o'clock, 4 o'clock, 8 o'clock and 10 o'clock. Schedule 40 6" pipe with be 2-face bends and 2-root bends. Schedule 80 6" or 8" schedule 40 pipe will be side bends. Just a quick overview.
Regards, Jerry
