Whip and pause technique which you describe produces the following: With a SMAW long arc the voltage increases. Voltage Affects the height and width of the weld deposit. High Voltage flattens the weld/Low Voltage piles up the metal. A shorter arc length requires less voltage because their is less resistance. Decreasing the arc length may (dependent on slope(volt/amp curve) of the particular welding machine) produce an increase in amperage. Amperage has the greatest affect on the penetration.
Whip out - increase arc length/increase resistance increase voltage and decrease amperage/decrease penetration, whip in - decrease arc length/decrease resistance/decrease voltage increases amperage/increase penetration.
Aevald
I knew this thread would go in all directions because folks apply the term to CC and CV, GMAW and SMAW.
Back to your question. I understand SMAW current vs voltage the same way you do.
As far as pipe goes, I'm not an expert, Hopefully JTMc will read this and offer his knowledge, he is really sharp. Anyhow. Yes a slight adjustment in length will help somewhat control heat in open root welds. The Hobart school teaches a whip and pause method with open roots and E6010 and I respect them to the point of using their training materials, DVD's etc for SMAW, GMAW, GTAW and FCAW. However, I was taught by an old pipeliner who burried the 5P right into the groove and dragged it slightly and made adjustments in depth of penetration guided by sound. The guy was like a stick welding Yoda. I teach both methods and don't argue with success as long as it's within the parameters set forth in the WPS.
I have a nice Ed Craig training video on GMAW and as I recall he deals with Inductance and Multi-tap slope as seperate items.
A little more looking takes me to Larry Jeffus Welding Principles and Appplications 5th ed where he says:
"Although GMA Power source is said to have a constent potential (CP) it is not perfectly constant,.... there is a slight decrease in voltage as the amperage increases within the working range. The rate of decrease is known as slope. ...... A machine slope is affected by curcuit resistance. Circuit resistance may result from a number of factors, including poor connections, long leads, or a dirty contact tube. A higher resistance means a steeper slope. In short circuiting machines, increasing the inductance increases the slope. This increase slows the current's rate of change during short circuiting and arcing intervals, Therefore, slope and inductance are synonymous in this discussion."
There is more to it than that, but that helps a bit I hope.
