Hello Lawrence, I too have been following this thread to see what some of the opinions are concerning the grounding issue as it is described here. In my facility we have 24 arc welding stations with all of the tables and booth structures built as one unit out of angle iron framework(thus they are essentially commonly grounded). We are using 2 Miller 8-paks and 8 XMT 304 multi-process power sources for welding machines. I also double in on some of the booths with LN-25's to do some innershield welding at times and also have about 6 other booths with access to CP 302's and SA22 feeders. Originally all of the arc welding power sources were commonly grounded to the booths(we use no earth ground rods in any of the booths, the only grounding to the machines is through the earth ground in the power panel, thus all of the machines are commonly grounded in a sense). After experiencing different levels of arc blow for a long time I finally went ahead and disconnected the common ground from the power sources and ran individual ground leads from all of the welding power sources and also the individual power modules in the 8-Pak to their own respective booths(in a sense they are still commonly grounded through the framework,however, they also have ground clamps that can be located relative to the welding that is going on), this made a drastic improvement in arc blow problems, however, it didn't solve the problem completely. I still find that on any given day it seems, depending on where students are welding and possibly what process they are running that there is still a certain amount of arc blow to contend with, having a good clean tight ground, welding away from the ground whenever possible and all of the other rules of thumb that apply to arc blow, still apply. I will be interested to see what else comes out of this thread. I also have 6 dedicated tig stations, however, they are only tied together by the panel earth ground that is part of the input power and have not experienced any odd sorts of shock issues or doubling up of current. Best regards, aevald
