oPetrol has launched new oxy-fuel cutting and welding torches that outperform conventional cutting torches in every feature.
Using ordinary gasoline or kerosene, this new cutting torch is safer, fuel economical and convenient. It is good news for both entrepreneurs and hobbyists. The torches are being exported to Japan, the USA and Europe.
0.8 gallon (3 liters) of gasoline can do the same job as one cylinder of 15 lbs (7kg) acetylene. In countries like Japan the saving on fuel cost is over 90%.
Ordinary gasoline from any gas station can be the fuel. With one gallon of gasoline, the torch can work 6 hours non stop.
Another interesting feature of such torches is the safety. Liquid-fuel makes back flash impossible into the fuel line. Compared to conventional torches, oPetrol torches demand less skill and are easy to master.
Kerosene is safer and usually cheaper compared to gasoline.
Until now, oPetrol has launched cutting torch, welding torch and blowing torches. Apart from hand torches, there are also machine torches. After a great success in domestic market, oPetrol is looking for success global wide.
For additional information please visit http://www.opetrol.com
