Hello fireguy, in a nutshell, if the structure was engineered with 100 ksi steel and required this strength specification, then the welding done with the 70 grade filler doesn't meet the requirement. The only possible way that I would see that you would not need to change this would be if the engineering was such that it was overbuilt to begin with. Good luck in the resolution of this issue. Regards, aevald
