By -
Date 03-03-2006 16:02
A5.4 is an ANSI/AWS (not ASME) Specification for Covered Electrodes. The 309MoL, whether it is the -15, -16, or -17 coating, is primarily used for joining SS that contains moly to CS. Normally, the 309MoL is also used to join dissimilar grades of stainless steel. I.E., 304 to 316, 316 to 2205 Duplex, 316 to 254 SMO. Although it can be used to join SS to CS, it is also used to join stainless steels that contain moly to other stainless steels that do not contain moly. The moly offers added pitting corrosion protection under most corrosion environments. A urea environment is a case where moly is more detrimental than beneficial. But, to specifically answer your question about what defects you will incur if you use 309MoL to weld SS to SS is.....probably none.
