Gerald,
As Lawrence stated, plasma is probably the safest and cleanest way to cut or gouge SS. I only know that there have been tested and documented evidence, which I don't have in front of me, that indicate that Carbon Arc Gouging SS is not recommended UNLESS all the contamination is carefully removed by grinding. With the heat of the gouging process, carbon can becoome trapped into the grain structure of the SS. When the SS cools down and the molecules close back up, the contamination can be trapped in the microstructure. The same scenario can be presented as if you are using a carbon steel file to file off the surface of SS, or using a CS grinding wheel. Gerald, respectfully, I don't think we can compare the carbon contamination to the carbon that is added as an element in the mixture of the melt used to produce SS as being the same thing.
Chuck
