I'm confused.
Every welding standard I've worked with requires the welder to follow a welding procedure specification when taking a welder performance test. The WPS may be prequalified as permitted by AWS D1.1, or it may have been qualified by testing for a welding process not prequalified by AWS D1.1 (GMAW short circuiting transfer for instance) or for work performed in accordance with ASME.
I've rejected test coupons when the welder does not weld within the parameters listed on the WPS. If the WPS lists vertical upward progression only, but the welder uses downward vertical progression, the test coupon is not accepted. If the WPS calls for E7018 eclusively, but the welder uses E6010, the coupon is not accepted. If the travel speed and heat input are limited and the welder exceeds the limits, the test coupon is not accepted. If the WPS limits the electrode diameter to 3/32 inch and 85 amps maximum, but the welder uses 110 amps, the test coupon is not accepted.
Every welder performance test report I've used or reviewed has a space for "WPS used". I reject the document if the WPS entry is blank.
I agree that the welder may not be qualified for all the "work" permitted by the WPS. For instance; the WPS may list "all positions", but the welder may be qualified for the flat position only.
I have not personnally seen a national welding standard or code that lists the welding parameters to be used, i.e., voltage, amperage, filler metal, wire feed speed, etc. If you have used a national welding standard published by API, ASME, AWS, etc., that lists that such information and requirements, please provide the name of the organization that publishes it. It would be interesting to read. I'm always interested in the latest requirements that being imposed by code/standard writing bodies.
I'm willing to learn.
Gerald,
The original post by chrcon quoted QW 403.5 which as you are aware is from ASME IX.
QW 300.2 states "These paragraphs require that each manufacturer or contractor shall be responsible for conducting tests to qualify the performance of welders and welding operators in accordance with qualified Welding Procedure Specifications, which his organization employs in the construction of weldments built in accordance wiyh the code."
As Al has said, if you don't follow the WPS in your weld test you fail.
Regards,
Shane
Hi 803056
Don’t be confused. Just simply remember the essential variables for each welding process and if your are strict…in fairness to the welders / welding operators...brief them on the applicable code / spec / WPS requirements prior to the start of performance test.
If the welder cheat during the test (e.g. rotate the test pipe while doing testing in 6G ) then, its alright to fail him/her on the spot, but if you fail them due those non essential variable you’ve observed, then be prepared…dispute may arise especially if your counterpart is knowledgeable...they may ask for your basis of rejection....shameful if your answers cannot find in the code / and spec that been agreed to use.
Ariel D C
I may have been misunderstood. (Not the 1st time).
My point is that a welder does not Qualify TO a WPS . Meaning the WPS is not one of the variables of qualification. A welder DOES Qualify USING a WPS.
If A WPS is written for Uphill or Downhill the welder could only use one progression. He will only be qualified for the progression as GOVERNED by the applicable variables listed for performance qualification. NOT the range of the WPS.
The KEY point is to NOT mix the ranges for performance qualification with the variables for procedure qualification.
Say we have a WPS for CrMo requiring 250 DegF Preheat . All of the variables to be used during production are within the qualification range of the welder. The welder was qualified on Carbon Steel. He didn't use ANY preheat during qualification. He is still qualified. He is qualified to use that WPS.
Another example, a person takes a GTAW test on pipe, Carbon Steel using ER70S-x wire. His WPS is for Carbon Steel ONLY. However he is also qualified to weld SS provided a wps exists for that company however he cannot weld on that material IF a WPS does not exist.
Have a good day. Sorry for causing any confusion
