It is my understanding that if the detailer does not list the "as detailed" tolerance" on the drawing, i.e., the welding symbol, then the "as fit-up" tolerances are added/subtracted to the basic dimensions listed for the joint detail.
condition 1 - "basic" plus "as fitup"
If the detailer takes advantage of the "as detailed" tolerances and adds those dimensions to the basic dimension of the joint detail in the welding symbol, the shop may then add/subtract the "as fit-up" dimensions to the as detailed dimensions.
condition 2 - "basic" plus "as detailed" plus "as fitup"
Good luck - Al
