Up Topic Welding Industry / Processes / Brazing procedure
- - By Welderuk Date 02-28-2006 02:18
Hi guys.
I am new to your site and would like to ask the following.
At my place of work the customer is asking for the brazing of our refrigerant copper piping to be qualified to ASME IX.
Can anybody tell me how involved the testing of the completed joint will be.
I presume the joint will have to be tested mechanically.
We have welding procedures for carbon steel but never produced one for brazing so any help will be greatly appreciated.
The maximum diameter of copper pipe we will braze will be 1in
Thanks in advance
Welderuk
Parent - By Bill M (***) Date 04-13-2006 18:14
You need to get a copy of ASME section IX, "Welding and Brazing Qualifications".
The Code specifies the qualification of the procedure and the qualification of the personnel that will do the brazing
Parent - By apankratz Date 02-20-2008 16:23
The procedure test will require both horizontal and vertical up tests in sufficient quantity to perform two tensile tests and two machro tests.  The size of pipe used for the test will qualify for twice the wall thickness and 125% of the lap length.
apankratz
