By -
Date 03-08-2006 23:29
Matt,
In your original post you asked if it were "possible" to weld over SS with a CS filler material. That is all you asked. Marty (MBSims) very politely answered your question. It is possible, but not advisable. From reading your post, it appears this vessel was a CS vessel with one layer of 309 (butter pass) and then another layer of 316L. Is that correct? If I may ask, why would you, or anyone for that matter, want to go and weld over the SS with a CS filler? What was the purpose of the SS layers in the first place if you were going to weld CS over them? Then, you asked if this was going to be a sound weld and could you expect to see any cracks after x-ray. You leave out so many details that no one can answer that question. For one thing, you make no mention of a PWHT. Marty and all the rest of us are only able to give opinions or recommendations based upon the details that are given to us. You failed to do that. That is probably why no one has tried to address your concerns. Matt, please don't take this wrong, but your last response sounded to me as rather disrespectful to Marty. I hope I'm wrong. If so, I apologize. As said, we will all try to help anyone if we have all the deails to make an accurate and correct suggestion.
Chuck
Am I corect that you have a 10" dia. pipe or vessel that is stainless steel clad in the inside. The ID cladding is a layer of 309 covered by a final layer of 316. the balance of the material is carbon steel. You are making a butt weld in this pipe or vessel, with a stainless steel root pass of E309. You then want to weld the balance of the joint with carbon steel...that will require welding the carbon steel on top of the stainless steel 309 root pass using the FCAW process with E71T-1?
