Up Topic Welding Industry / Technical Discussions / A36/A992 WPS's
- - By ctinker Date 03-10-2006 23:54
The project we are on has A992 structural steel along with A36 plate,angle, etc. I have a prequalified, unlimited thickness D1.1 wps for A36 P1 to P1. I also have a qualified ASME Section IX procedure for P1 Group 1 to P1 Group 1. The Section XI procedure was qualified using A36 plate and E7018 rod. My question is this: Is our ASME wps acceptable for welding A992? My version of Welding Pro-Write states A992 as a P1 material, but I can't find the P number in any code book. Also, Under D1.1, does a column base plate welded with 100% penetration and 150 deg. preheat need to be UT or RT? I can't find any info on this as well.
Any help would be appreciated
Chris
Parent - - By chall (***) Date 03-14-2006 13:53
Refering to QW-422 in Section IX:
A992 is an S1, Gr 1 material. If you have a PQR qualified with P1 material and notch toughness is not a factor, you may use the procedure for welding on the A992 material (within the established limits).
AWS D1.1 does not use P grouping terminology. Since A992 is not prequalified in D1.1, you would not be able to use the prequalified WPS for this application.
I don't know the answer to your question about UT.
Charles.
Parent - - By jwright650 (*****) Date 03-14-2006 14:32
Charles,
AWS D1.1:2006 has ASTM A992 listed in Table 3.1 Group II as a prequalified base material(it was added in AWS D1.1:2000).
As far as UT or RT requirements...that would be up to the customer's specs as to whether or not it is required.
John Wright
edit: as far as the preheat, if using AWS D1.1 Table 3.2, it goes by the thickness to decide the preheat/interpass requirements.
Parent - - By chall (***) Date 03-14-2006 14:38
Apologies. I obviously missed that on my first pass. It pays to go slow, which I plainly did not do. I appreciate the correction.
Charles.
Parent - By jwright650 (*****) Date 03-14-2006 15:23
Charles,
It was kinda funny, because after I read your reply, I was in a terrible panic to get my 2006 D1.1 off the shelf to see if something had changed. That material is used in about 95% of everything we do here and I couldn't turn the pages quick enough to get to Table 3.1...LOL.
John Wright
Parent - By CHGuilford (****) Date 03-14-2006 14:40
Actually, D1.1 - 3.3 refers to Table 3.1 for prequalified base metals and A992 is listed in Table 3.1 Group II. That means it can be used in a D1.1 prequalified WPS.
FYI- A992 is the same as A572 grade 50 modified to AISC Techincal Bulletin #3. The modification is mostly a limitation on the yield,tensile ration. For all intents and purposes, A992 adn A572-50 are the same thing. At present A992 doesn't apply to plates, just structural shapes but I have heard that might change.
I know- more info than was asked....
Chet
(John beat me by 8 minutes)
