Up Topic American Welding Society Services / Certifications / Qualification Validity AWS D17.1
- - By Jameslu Date 03-15-2006 08:27
AWS D17.1 para.4.2.3 Qualification/Certification Validity
In accordance with para. 4.2.3.1, A welder has two years validity when he got qualification.
And, para. 4.2.3.2 Extended Validity. Qualification of a process
may be extended indefinitely provided an auditable
record is maintained from the date of the initial qualification
that verifies that the welder/welding operator has
used the process within a six month period to weld applications
normally welded by the certified individual.
What kind of auditable record should be kept?
A log book?
Any example?
Parent - By tito (**) Date 03-15-2006 13:05
I think what you are refering to would most commonly be called a "welder continuity log". It is a simple form that lists the welder's name, stencil, WPS qualified with, initial qualification date, and then columns for 6 month re-cert dates.
here is somewhat of an example minus the actual colums and rows that would be visible on the form.
WELDER CONTINUITY LOG
NAME STENCIL WPS DATE 6 MO RE-CERT
john doe j (wps #) 01-01-00 06-01-00 /01-01-01
edit:well that doesn't actually come out looking like it supposed to when posted, but you get the idea.
- - By Mwccwi (***) Date 01-11-2011 16:50
Dragging up an old post while looking for an answer. Initial qualification is valid for 2 years.
The question is does the 6mos start at the end of the 2 years and extend it for an additional 2 years?
Parent - By waccobird (****) Date 01-11-2011 17:27
Mwccwi
It says
record is maintained from the date of the initial qualification.
record starts with the qualification and every 6 months that weldor welds the process qualified in an entry needs to be put in to the continuity log to enable indefinite qualification by auditable .
Does this help Martin
Good Luck
Marshall
