I have a potential project that would require welding a wrought alloy (6061 probably) to 206.0. It is a rear end for a 240mph road race car, and the weldment would function as one-of-three suspension links mounts. It won't get too hot in service (200ยบ or less), but will be subjected to severe vibration, and shock loads in the area of 3,500psi. The weldment would be inspected before every race, and the customer knows that this is probably going to be a consumable part.
The cast alloy is set in stone. Is it weldable? If so, what wrought alloy and filler alloy would you recommend? Interpass temps? (I'm planning on 3-passing the entire weldment, with one pass on opposing sides)
Thanks guys.
