Up Topic Welding Industry / Technical Discussions / welding times with SSFCAW
- By bleadonman Date 12-19-2000 09:47
can anyone help with what welding times in feet per hour I should allow for semiautomatic SSFCAW using 1.8mm diameter E70Twire in the horizontal 2F position. For 6mm fillet and 8mm fillet welds. the welding is to be carried out on site in good coditions with few access and weather problems.Thanks for your help.
