Hey Marty Chuck!
I was hoping that your link worked but, apparently it does'nt...
I'm not disagreeing with you Marty or Chuck!!!
Personally, the only thing that would remotely make sense here is the very low probability that the chemical composition of the filler metal was such that, 1.an unusually high percentage of ferrite needs to be present,
2. interpass temperature was at least 2-1/2 to 3 times the recommended amount or even higher which as a result, transformed most of the greater than normal amount of ferrite originating from the fller metal, into "delta ferrite" otherwise known as "gamma iron" compared to "alpha iron", resulting in enbrittlement of the welds due to the formation of sigma phase.
3. As a result of excessive dilution, enough of the ferrite that originated from the filler metal, precipitated into the HAZ...
Check these 2 .pdf's... I found them interesting enough...
http://www.arpansa.gov.au/pubs/rrrp/csiro1-10.pdf
http://www.arpansa.gov.au/pubs/rrrp/csiro11-14.pdf
I know it sounds like mush but, under certain conditions it could happen - does cheap, counterfeit filler metal originating from the "far east" ring any alarm bells??? However, if the filler metal came from reputable sources such as Avesta/Outokumpu, the previous hypothesis would not hold any water...
Marty, this one might help shed some light towards your query:
http://www.bbs-systems.com/Pages/PagesGerman/
BegriffeUnDefinitionen/Fachbegriffserkl%E4rungen.html#FachbegriffeInfluenceAnker
I apologize for not keeping the link active in this thread...
I wanted you fellas to be able to read my 2 cents worth regarding the so-called excessive ferrite content in the HAZ or whatever this lab was trying to explain!!
SSBN727
Run Silent... Run Deep!!!
