Hello Hank, I believe you're in the right store so to speak, although I'm not the one to answer your question. I do have one of my own though, why exactly is this of such great importance to you or your colleagues? Are you having quality control issues regarding a particular welding scenario or is there something else going on? There must be a bit more to this story than just whether 25% CO2 can exist in it's liquid form while in the presence of 75% Argon in the cylinder. Are you experiencing a freeze-up problem of the delivery of the shielding gas due to excessive draw-off rates or high-humidity in the air in the proximity of the welding being done? Is this possibly relevant to a refridgerant type system whereby a liquid changing to it's gaseous form is causing a drop in temperature and causing freezing of the regulator and thus cutting off the shielding medium? You've sparked my curiousity, more information, Please. Regards, aevald
