James, John
Due to improved rolling practices over the last seventeen years since the green ASD manual publication, the AISC has relaxed its CVN requirements in the new manual for what was previously designated as Group 4 and 5 rolled shapes. The green ASD Manual, (A3.1.c) indicated that any Group 4 or 5 steel that was to be splice welded using complete joint penetration, regardless of thickness, was required to be indicated in the contract documents to be supplied with CVN testing, which is at an additional cost to the fabricator.
Now, the new manual has excluded the rolled shapes chart (page 1-8 Table 2) that indicated the rolled sizes and their group designations, and in A3.1c, the words "Group 4 and 5" is eliminated and replaced with “rolled heavy shapes with a flange thickness exceeding 2”.........
There's even a footnote in the shapes listings that states"Flange thicknesses greater than 2" special requirements may apply. See A3.1c".
I realize that we are bound by the requirements of the contract documents, but now, CVN testing is only required when the flange thickness exceeds 2", and that member is spliced using complete joint penetration welds.
Some engineers will not be aware of this change and will continue to require CVN testing for the old Groups 4 and 5, but, there's no point in paying for CVN testing if we're no longer required to. A quick phone call to the EOR for verification might save some money.
So, to answer your question # 1, group designations 1 through 5 no longer exist.
The answer to your question #2 can be found in the new manual on page 7-80. The height of a 3/4" A563 heavy hex nut is 47/64. It will not vary from manufacturer, because it has to meet ASTM A563 criteria.
John, there are other fabrication changes regarding the heavier shapes. One change is that there is now a specific height requirement for weld access holes, along with a minimum and maximum height limit.
