Hello George, you,ve sparked my curiousity here a bit. A couple of questions as to the application of the stainless FCAW here. As Chuck stated, typically SS FCAW would not be used for any type of full pen application, x-ray or not. I could see possibly using a tig or GMAW root and a hot pass in conjunction with an Argon purge and then switching to the FCAW for the fill and cap, yet the multiple process scenario would present some complicating time issues, etc. Since the FCAW will generate slag, the open root scenario would present some sort of slag cleanup issues on the internal bore of the pipe unless it were large enough to allow internal access to the root area for cleanup, I'm not quite sure that it would work without contamination issues as well and if you tried to use a purge would it need to be of the same gas makeup as the shielding gas? As I said you've sparked my curiousity. Additional information would be appreciated. Regards, aevald
Without trying to offend some people and make this a "sales forum", I will try to answer your concerns. Usually the flux from a FCAW will rise to the face (top) of a weld, including a root pass. Like has been said by all of us, FCAW is usually not used on a root pass if x-ray quality welds are required, but it certainly has been done. The smaller the root opening, the greater chance of the flux rising to the surface. Too wide of a root opening and the greater chance of burn-through, and flux contamination. Both Avesta and Kobe produce wires that can be used in out-of-position welding. I'm not going to say which wire I prefer because I've been criticized by some for trying to make this forum into a sales forum (whatever that meant). Let me say that I work for Avesta Welding and have seen fabricators use the Avesta wire on open butt welds successfully. The things that made is successful was to use the smaller root opening and rapid travel speed. You will not be depositing lot of metal, but FCAW isn't the 1st choice for open butt welding. Again, this is strictly my opinion and experience. It may not work for everyone.
Chuck
