Up Topic Welding Industry / Technical Discussions / Welding Haynes 230
- - By arcvoice (*) Date 03-27-2006 17:01
Does anyone have experience welding Haynes 230 to inconel 718. I'm looking to do this and would like to now the do's and don't's of the two materials..I plan on using Gtaw process with a 95ar/5-H gas mixture..
Parent - By Lawrence (*****) Date 03-27-2006 18:48
This ought to be a big help.
http://www.haynesintl.com/pdf/h3000.pdf
Are you using the Haynes as a hardface filler to build-up wear areas on the Inco?
If you are actually joining componants of the two different materials, I have always liked Has-W (it is a possible filler in the above linked chart) for its forgiving ductility.
