Assumed worse case, it may be that it's a much simpler form. I didn't read enough clarity in the initial statement to say for sure which is why the preface " Assuming a TKY ".
Without being there in person, or having seen design drawings or any other sort of input other than is found here, I assumed a tky. It may be that it's very simple design no tky to it. However even with that, there is the minimal thickness requirement. That much was stated clearly, so either way, it should revert to annex k by my interpretation.
