Hi Jaybird!
May I ask what your IPM's (Wire feed speed) you're running with those parameters???
The reason I ask is because your volt/amps settings are in the spray transfer range and, if your using 100% Helium for your shielding gas then you must be getting some real good penetration...
It's been awhile since I heard of someone welding Ni-Al-Br (Nickel/Aluminum/Bronze)...
May I ask what you're building??? What shipyard???
SSBN727
Run Silent... Run Deep!!!
