By -
Date 04-12-2006 14:28
Hi, there
I have a welding drawing in my hands which involves GMAW welding of stiffeners on a plate. The drawing points the starting point of welding, indicates a chain weld and gives gives a sequence of 11x75 (for one stiffener) , 15x75 (for another stiffener - different length), 19x75 (for another - different length), 57x75 (...) etc. No other information is given... So, what I don't know and can't understand is if I'm welding 11mm (15, 19, 57) and leaving 75mm and so on or if I'm welding 75mm and leaving 11 (15, 19, 57) depending of the stiffeners' length.. :-/
