Up Topic Welding Industry / Technical Discussions / Testing of welds by AWS procedure
- - By shashikant Date 04-18-2006 10:24
I understand that testing of welds at times is done by AWS procedure. I would be grateful if someone could provide me short information on - for which particular application or particular job is AWS procedure most important/compulsory for weld inspection?
Parent - - By ajoy (**) Date 04-23-2006 10:25
AWS is applicable for structural welds.
Commonly, AWS D 1.1 would be used for general structural work associated with ASME VIII and ANSI 31.3
Parent - By BamaDave (**) Date 04-23-2006 16:16
The testing associated with structures as related to NDE shall be documented in the original purchase agreement/contract, as no major NDE is required unless specified, other than visual. This is somewhat of a weakness of the system however if NDE is required the procedures utilized are required to meet AWS D1.1.
