"As I understand it,, the R70 is an 'in position' only wire, and the 7100 is an 'all position' wire."-quote
You are correct, the "0" means flat/horiz only, and the "1" means any position.
Is your WPS qualified or prequalified? Also are you working to AWS D1.1 or another code?
We use prequalified procedures here and we use both ESAB 3/32" E70T-1 (Dual Shield 111-AC) and ESAB 1/16" E71T-1 (Dual Shield ARC 71).
Like you stated, for some things the faster freezing wire does stack up quicker.
John Wright
