By rn01
Date 04-24-2006 12:37
There is no indication that welds were stamped. B31.1 provides an alternative to stamping where "the employer shall maintain records which identify the joint with the welder or welding operator." For the case in question, it appears that "weld maps" were created that identified the welds on each piping system (with the welder's symbol included) which would comply with the code requirement. The weld maps now appear to be missing and we are trying to determine the path forward if the maps can not be located.
