Up Topic Welding Industry / Technical Discussions / Corten A & B
- - By hsari Date 04-24-2006 06:54
Do I need to make a requalification for corten steels acc. ASME section IX if I have PQR` from P1.
In fact What are the ASTM equivalents (P no and group No.) of Corten A and Corten B steels?
Huseyin Sari
China
Parent - - By ajoy (**) Date 04-24-2006 08:04
You will have to requalify the procedure because the steels are not listed as ASME materials in sec IX or ASTM materials.
Parent - By hsari Date 04-24-2006 08:10
Thanks for the info.One more question is,
We are using ASME standarts for PQR`s ,WPS`s etc.
To make a new qualification with Corten A and Corten B, which P no. shall be selected for testing acc .to ASME section IX.
Parent - By Aimee Mann Date 06-19-2007 10:32
Hello Sir
We need a Corten A or B URGENTLY since we participate some tender
Would you have any help us about it, please?
Thanks, Rosa.
Parent - - By MBSims (****) Date 04-25-2006 03:58
The ASTM standard for CorTen plate is A-588. This does not have a P-number, but is assigned S-number 3 in ASME IX. A procedure qualification on P-number 3 also qualifies for S-number 3. You will have to also look at the A-number of the PQR to be used to make sure it covers the electrode. Corten is usually welded with E7018 or E8018-W2 for color matching. I have also seen it welded with E8018-C3.
Parent - By Aimee Mann Date 06-19-2007 10:33
Hello Sir
Thanks, Rosa.
